Ir para o conteúdo principal
Apple's top-of-the-line smartphone for 2021. Released September 24th, the iPhone 13 Pro Max sports a 6.7" ProMotion OLED display, a new triple rear camera system, and 5G connectivity. Successor to the iPhone 12 Pro Max.
20 Perguntas Visualizar todos
Power down iPhone 13 with broken/dead screen
I am trying to turn off and power down my iPhone 13 ProMax with a cracked/dead/dark screen. Without being able to see anything on the screen or use the screen I can't use the off-slider, nor can I tell when the apple logo appears. So the volume up/down and power button trick won't allow me to shut it down so I can replace the screen.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
If the screen needs replacing it is quite safe to remove it and the shield and disconnect the battery connector before moving on to the screen connectors. There is a replacement guide here.
Esta resposta foi útil?
Pontuação 2
yes, u can we have steps to doing so as well its about $139.99 to $400 to replace the screen
Pontuação 0
1 comentário:
sorry man i wish things where cheaper like omg
por
try pressing the volume up then volume down the power button for 10 second. your phone should be off by then
Pontuação 0
Adicionar a sua resposta
ghn1000 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 410
