Which bit do I use to remove back?
Looking for the correct bit to open my Air M2. P5 seems loose when I try to use it.
Esta é uma boa pergunta?
Pentalobe 1.2 5 point bit. iPhone is 0.8 and MacBook is 1.2
Esta resposta foi útil?
Hi
I believe it is a p5 that is used
If a p5 doesn’t feel tight enough try a p6
If it’s too big try a p4
Hopefully this helps
Any questions please ask
P5 is correct. Ordered a new P5 bit and it worked great. Also purchased the magnetic project mat and highly recommend it!
I find that anything magnetic is handy:-)
A Penalope 5 screw bit probubally because apple uses the P5 bit on all MacBook pros post 2012, and airs post 2018. I do with they would change it.
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 585
1 comentário
Example
https://www.ebay.co.uk/itm/272489549449?...
por [deleted]
