Top load whirpool problems - WTW4815EW1
Have any problems and can not figure out. Just fails to run, once it starts making spinning or agitating noise. Does not seem to completely empty. Have drain pump off now. Should impeller spin freely?/ It builds up tension then moves. Any other tests I should do while accessing the bottom?? The belt looks good and it and tub spins, The agitator does not spin freely, but spins with tub. It failed basket speed test and I think shifter test. Can confirm when i hook it back up.
Update (08/02/2022)
Replaced speed sensor assembly and works.
Esta é uma boa pergunta?
