Ir para o conteúdo principal
Guias de reparo para o 3º drone mini de baixo peso da DJI. O DJI Mini 3 Pro foi lançado em maio de 2022. Número do modelo: CP.MA.00000488.01.
GPS module not detected
After a crash, the drone does not detect its gps / IMU module.
There is no apparent damage on the drone, but it can’t detect gps anymore, the gimbal doesn’t move, and the IMU reports an error.
With that, the drone motors won’t start.
Everything else works. Still can take pictures, make films, etc.
Could a gps/IMU module have been broken at impact, but not no physical damage in the outer shell?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Hi there. Trying to calibrate compass or IMU simply get stuck and does not work.
I was thinking of opening it to see it it’s a loose cable, but wanted to get a sense if it’s a thing or not…
por
No crash drone tower sight fly good fly next time fly no fly
por
Adicionar um comentário
3 respostas
Yes. It could be as simple as a connector becoming loose or a quick calibration. There was some laptop software that would do a complete calibration. You could get it from DJI website.
I have had to replace broken components but first I would do a gps and IMU calibration.
Esta resposta foi útil?
Pontuação 0
If calibrating the drone does not restore the GPS, try replacing the module. I made a detailed video tutorial here Substituição do módulo de GPS do DJI Mini 3 Pro
Pontuação 0
Man I have the same issue, but I open the Drone and discovery the flat cable of gps are broken.
Just buy one in alyexpress and be happy.
In YouTube have a video whit disassemble mini 3.
Pontuação 0
Adicionar a sua resposta
feliperosacunha será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 3,379
