Ir para o conteúdo principal
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
163 Perguntas Visualizar todos
Xbox One Controller Vibrator wires detached from motherboard
Hello, I was replacing my LB/RB bracket and the wires for the right hand side vibrator came out. Can I use glue to reattach these or do I need to buy a soldering iron? One image is how it should look. Cheers
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Find a mobile phone repair shop. They should resolder the wires back on for you. Save you buying an iron if you don’t need one. Get people coming into our work asking to solder all sorts.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
you need a soldering iron as glue isnt conductive
Pontuação 2
Adicionar a sua resposta
Lewis Bateman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 211
