Radio shack MD-1160 won’t turn on
My keyboard has no power when plugged in to the dc plug. I have taken the unit apart and have found nothing unusual on the circuit boards other then blackened grease where the on off switch runs. Any suggestions?
Esta é uma boa pergunta?
6 comentários
Can you take a picture of the circuit board(s) and upload it here? Adicionar imagens a uma pergunta já existente
por Andrew S
Hi @suzang,
Have you checked that the AC/DC adapter power supply that plugs into the keyboard is working OK i.e. that there is 9V DC on the plug at the end of the cable?
If you can't test if the 9V DC output adapter is working, then try inserting 6 x "D" size dry cell batteries ( 6 x 1.5V D cell batteries = 9V DC) in the keyboard's battery compartment and check if it turns on.
Make sure that the DC plug adapter is unplugged from the keyboard if you try this as plugging in the adapter disconnects the battery's power supply to the keyboard
por jayeff
I have finally put batteries in and it works!🤣. So I guess now I will need to take pics of the two Circuit boards so y’all can see if I’m missing something. I will also be purchasing a new 9v plug for the keyboard.
por SuzanGeorges
@suzang
Here’s how to add photos!
por HelloMacOS
@suzang
Have you tried a different, known working compatible 9V DC power adapter to see if that worked, you didn't say?
por jayeff
Exibir mais 1 comentário
