Ir para o conteúdo principal
The Lenovo Ideapad 110S-11IBR was released in September 2016 by Lenovo.
9 Perguntas Visualizar todos
Lenovo Ideapad 110S keyboard replacement
Hi,
I have problem with some keys on keyboard, they doesn´t work. I want to replace whole keyboard, but I´m not 100% how. It looks like I have to disasamble all components inside. Specifically I am not sure about one of display cable. I want to ask you about some manual how to disassamble keybord. Some pictures or video, text will be ok too.
Sorry for my English. It's not my native language.
PS. Thanks for answer.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here's the hardware maintenance manual for the laptop.
Go to p.45 to view the necessary pre-requisite steps and then the procedure to remove the upper case assembly. The keyboard is part of the assembly.
On p.58 Item #2 you will find the part numbers for all the country and colour specific keyboards available for the model.
Search online using the part number only applicable to your particular model variant i.e. country and colour (BK=black, WH=whlte) to find suppliers that suit you best. Usually the part number can be found on the underside of the uppercase assembly if you wish to verify that you're ordering the correct one
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Majo Siket será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 213
