Ir para o conteúdo principal
Released September 24th, Apple's 2021 flagship smartphone features a 6.1" ProMotion OLED display, a new triple-lens rear camera system, and 5G. Successor to the iPhone 12 Pro.
Broken LiDAR Scanner iPhone 13, rear system change
Hi, I replaced a damage iPhone with a pulled rear system form another iPhone, but have not transferred the former LiDAR Scanner. As there is a manual for this on here, I used the LiDAR sensor from another iPhone, but it seems to be paired to the iPhone as well. Has anyone ever exchanged a LiDAR Scanner successfully, so one that was not installed in the original device? The measure app (to test the LiDAR) just freezes….
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
The lidar in the pulled chassis probably isn’t compatible with the motherboard. Normally everything must be swapped over between chassis’s.
Esta resposta foi útil?
Pontuação 1
It might be possible you did everything correct. The housing might have the wrong LiDaR filter installed. A lot of housing suppliers will use something that looks right from the outside but doesn't function like the original filter. My guess is that it's not even a filter at all, just some paint. If you still (it's been 3 years) have the original housing, you might be able to transfer what's left of the original filter to the new housing (after you scratched off the knock-off paint inside the back glass)
https://www.reddit.com/r/mobilerepair/co...
Pontuação 0
Adicionar a sua resposta
MacMarcus será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 809
