Ir para o conteúdo principal
Smartphone Android topo de linha da série G da LG, lançado em abril de 2019.
Re-Assembly Adhesive Advice
I am looking to replace the battery in my LG G8 ThinQ. I've found the guide, and the replacement battery itself. The one step I'm having difficulty finding advice on is how to re-adhere everything once the battery has been replaced. Any guidance or advice would be MUCH appreciated!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I guess my main question is what adhesive material should I use to hold everything together again.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
put a squiggle down like a small one just enough to hold like b,t,e,a,c,d6000,7000 adhesive so Ya that Ezzy just makes sure u would be able to get it out too if needed to replace the battery again u know how batteries are and Carful of the board and Ribin cables it is glue u know
Esta resposta foi útil?
Pontuação 1
5 comentários:
super glue can work too but it's not really meant for it can melt certain plastic screens and battery's so do some research
por
I'm not sure I follow. Put a squiggle down?
por
small amount but not too much
por
I'm looking to do this for someone and I'm not sure what the b,t,e,a,c stand for as far as options to use.
por
@andrewwith31847 I see what you mean; a little more leaning toward "proper" english might have helped in this case.
Anyway, I believe they're trying to tell you that pretty much any of the common glues will work; combine the letter with either of the numbers - e.g., b6000, t7000, e6000, c7000, etc.
If you look up screen glue on AliExpress, it appears B7000 and T7000 are currently popular choices.
I would actually suggest looking for a sheet of precut adhesive first, though. If available, it will be an exact fit and will avoid any possibility of problems due to glue getting in places it shouldn't be.
por
Adicionar a sua resposta
Ryan J Carney será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 639
