Ir para o conteúdo principal
Documentação de reparo do smartwatch Fitbit Versa 2. Lançado em setembro de 2019.
Can the back Panel be replaced?
The back panel on my Fitbit needs to be replaced. The section right by where the pin goes has been broken and no longer hold the pin in on the strap. Can this be replaced and if so what do I need to do? Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi
You can indeed replace it but it involves a full housing shop
Here’s a video showing how to do it!
https://youtu.be/ZeT1Zmbt9QE
As for the part you can probably find it on eBay or AliExpress
And for tools I recommend iFixit tools as they are top quality and will get your job done very nicely:-)
So maybe pick up one of their tool kits as they will have the bits and pieces you will need! But it’s up to you where you get it from
If you need any advice with doing the repair just ask
Hopefully this helps
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Sylvia King será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 686
