ink very light on paper
new carrtraigr ink light
Esta é uma boa pergunta?
The Lexmark T650 series does not use corona wires. Some possible causes of light images are:
a) The darkness is adjustable - on the printer select: menu : settings : quality menu : toner darkness. A larger number produces a darker image.
b) The toner cartridge might be empty. If this is the case, shaking these cartridges can reposition enough toner to provide a short term quality improvement.
c) Light images may be caused by an old OPC (Optical Photo Conductor) roller that is built into the disposable toner cartridge.
Esta resposta foi útil?
Laser printers use a corona wire to transfer the ink dust to the paper electrostatically. A thin image often is a failing corona circuit or dirty wire.
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 21
Ao todo: 492
