Samsung 204BW Display Capacitors
What capacitors do I need for a Samsung 204BW display? And do my capacitors look like they need replacing? Thanks in advance.
Esta é uma boa pergunta?
@clatyn I am linking you to RS Components UK-I believe they offer free shipping
470 uF 25V Capacitor - Order 5
1000 uF 25V Capacitor - Order 5
The total should come out to about £6 excluding VAT
Esta resposta foi útil?
The size is printed on the capacitors themselves. Top left top is domed, far right looks similar and has leaked on top and bottom one looks like it might of swelled too.
It may save time and most probably cost just the same to get the 204BW capacitor replacement kit. Depending on your location as regards shipping etc. of course.
Hi @clatyn
OK
Here's a supplier that actually states part of the values (not the voltage rating only the capacitance value) and number of each of the capacitors required except the 400V-450V ones (capacitance value and number required unspecified - see note regarding these.)
You may have to open it up to find what you want and then try this supplier to get them. The capacitance and voltage rating options are on the left side of the page.
Unfortunately I'm based in UK. So the shipping is actually more expensive than the product. 😥
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 140
12 comentários
What is the problem with the display?
por Andrew S
I have to press the power button multiple times. Before screen displays. Seen from other monitor fixes it's most likely the capacitors.
por Clatyn Janes
@clatyn Can you take the back off the monitor and upload pictures of the circuit boards? Adicionar imagens a uma pergunta já existente
por Andrew S
Currently using the monitor. Can you answer original question?
por Clatyn Janes
@clatyn Sorry, I don't have that monitor, therefore, I don't know what capacitors are used on its power board, which is information I would need to recommend replacement capacitors.
por Andrew S
Exibir mais 7 comentários
