Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
One of the battery cell is swollen
Only one of the cells is very swollen, only one, is it possible to remove just that cell or do I have to replace the entire component?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Once a battery gases (one or more cells) its the end of the battery. Basically there is a short between the anode and cathode of the battery. It might be short lived but charging the battery will likely cause the short to occur again! The next time it could be worse than just a ballooned cell! You don't want it to go critical causing a lithium fire.
Time to replace the complete battery! MacBook Pro 13" Retina (Early 2015) Battery and here's the guide Substituição da bateria do MacBook Pro 13" com tela Retina de início de 2015
Imagem de MacBook Pro 13" Retina (Early 2015) Battery
Produto
$79.99
Esta resposta foi útil?
Pontuação 2
No, change all battery. If one cell is swollen that means others could also do that. Also cells are connected via ribbons so trying to remove it you will short it. I had HP laptop with swollen cells and they was punctured with needle, technically nothing happened but for your own safety DON'T do this
Pontuação 1
1 comentário:
What about removing the battery and waiting a few days? Once I had a swollen iPhone battery that shrunk in a few days after replacement.
por
Adicionar a sua resposta
leomussa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 164
