Ir para o conteúdo principal
Slightly loose side panel
My side panel on the brand new Aerox 5 wireless is slightly loose. It is barely visible with the naked eye, but you can feel it during gaming as you grip the mouse and move around - it is kinda annoying.
Does anyone has the same issue or know how to fix that? I think that it may be fixed just by tightening some screw inside but haven't opened the mouse yet - since I did not find any teardown online even for Rival 5 that has the same body (to be safe - not used to modding like this).
I am attaching the example of what the issue sounds like since it is barely visible in person :)
https://youtu.be/PKzMLFvvDh8
https://youtu.be/F5WX_Woki84
Thank you for any reactions.
UPDATE:
I have inserted a piece of paper to reduce the clearance and it seems to work.
Going to get some black paper from my local store and trim it to blend in as a temporary solution until the teardown/disassembly tutorial comes out.
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Timeline 4:30 of this video will show you how it fits together so you can see the inside:
https://www.youtube.com/watch?v=BVFyvOM3...
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks for the submission. However, the mouse that is shown at 4:30 is Razer Naga Pro - which won't help me here with Aerox 5 disassembly.
Nevertheless thanks for trying to help.
por
Have you managed to fix this issue?
I have exact same problem.
Pontuação 0
Adicionar a sua resposta
Tomáš Dohnal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 65
Ao todo: 2,419
