Ir para o conteúdo principal
How to fix it kernel power 41
hello morning
how to solve the kernel power problem on my 14s Cf0044tx laptop, I'm having a 41 kernel power problem. I always have a bluescreen, can you help me fix it?
regards
MeO
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
i need more info what did u do or try to do when u got the blue screen
por Compartilhar
@hay yew The bluescreen often occurs when I use the laptop to do office work such as typing in word or excel or browsing using Google, after that I experience a bluescreen, the laptop is used for 1 hour or 30 minutes after that it's a bluescreen, how do I fix it?
por Compartilhar
this sounds like u have a corrupt update or a bad error u can try the reset if that doesn't work it could be a lot of things but try fresh restart first u can try to keep the data but sometimes it won't allow depending on the problem it incounters
here u go
put on a flashstick or just run and it will work if u have on flashstick u got windows 10 repair key
https://www.microsoft.com/en-us/software...
por Compartilhar
Adicionar um comentário
1 resposta
here u go
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Fazqi Madara será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 595
