What type of tools needed to open the Bose Speaker
what type of tools needed to open up up tj Bose Speaker
Esta é uma boa pergunta?
Hi,
Here's a teardown video that may help.
One of the comments below the video mentioned that the screws on the bottom are a 5 point security torx screw so at a minimum you will need a Torx 5 point tamper proof screwdriver. Unfortunately the size wasn't mentioned e.g. T5, T6 etc
Esta resposta foi útil?
Thanks so for the vid, I’m looking for the charging unit ? Any ideas
@Olu Osibo
If you get an AC/DC adapter with the following specs it should be OK
Input : 100-240 V AC , 50/60Hz
Output : 5V DC 3A
Output plug : USB-C
Here's an example
Of course the adapter's AC input plug design would have to match the wall power outlets where you are so that you can plug it into the wall power outlet ;-)
I found the link to the bits that he used in the video on amazon, it’s only £7/$9 here: https://amzn.eu/d/dg8hV9T
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 66
Duração total: 817
