Ir para o conteúdo principal
Important power lines and their resistances?
Hello. I have an iPhone 6S logic board with a small current leakage (20 mA). Could somebody please tell me what are the important power lines on this phone and what are their expected resistances, so that I can measure the resistances of my board' s power lines and compare them to the theoretical values?
Update (06/16/2022)
iPhone 6S, water damaged. Hasn' t been dropped. Doesn' t power on. The resistance of the PP_VCC_MAIN is around 400 ohms, which I think is normal. I need to know which other power lines I should measure to find what' s the problem.
Esta é uma boa pergunta?
Pontuação 0
5 comentários
How do you know it has a 20mA current leak? When you measured PP_VCC_MAIN did you have the multimeter in diode mode with red probe on ground?
por
I connected a DC power supply at 4V to the battery FPC, and the current draw was 0.02A
por
@cavemahn What is the diode reading on “PP_VCC_MAIN” and “PP_BATT_VCC” Red probe on ground.
por
PP_VCC_MAIN is 450, and PP_BATT is 660. Shouldn't they be smaller?
por
@cavemahn PP_VCC_MAIN “0.420” PP_VCC_BATT “0.414” You said it draws 20mA is that before prompt to boot? If so what does it draw when prompted to boot?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
vcc_main is the main power rail but there are numerous power rails. can you tell use more about the phone, any liquid damage, has it been dropped. does it power on ?
Esta resposta foi útil?
Pontuação 1
A water damaged phone does not work because the water has created a short in the circuit. That short creates a higher current draw which damages components and creates a bigger short usually with some carbon burn. Measuring power bus resistance will likely get you nowhere.
Pontuação 0
Adicionar a sua resposta
Sus Amogus será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 126
