Will charge 3 connect to Extreme
Will a JBL Extreme 2 or 3 blue tooth to my Charge 3 ? Is Extreme Connect or Connect +, I believe Charge 3 uses connect?
Esta é uma boa pergunta?
As your Fitbit watch has bluetooth capabilities, this should not be an issue. If you follow these steps you should be able to pair the two:
Note Should this not work please power off both devices, and start the procedure again. I hope this helps and if not please return and we will assist further to get you all set!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 172
