I cant remove my playstion from safe mode and only shows red light?
Remove From Safe mode
Esta é uma boa pergunta?
Hi @bigbio
I can't gauge what you mean based off the information available so it might be a good idea to go to: Adding images to an existing question. However i can give you some vague advice:
Firstly, can you research and see what you find. I couldn't find anything
Then, maybe try the hard drive swap and see if that works (That's unlikely)
Do you get a display out?
Also, do you happen to be able to plug in a controller and interact with it.
If you try any option in the OSD, does it flash up an error?
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 19
