Ir para o conteúdo principal
A laptop by Toshiba with a 15.8" display and runs Windows. Has a straightforward repair similar to most laptops. Requires only a screwdriver.
4 Perguntas Visualizar todos
How to safely remove plugs
Hi,
I would like to know how to safely unplug some connections underneath my keyboard. My first attempt ended in frustration as the plug would not come out of the socket. I did not want to force it , as I was afraid I would break the connection. Every video I see online shows the plug coming out with ease, but not mine. Am I doing something wrong?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Off hand, I would try pushing down gently on the two white tabs in the indent on your photo and pulling gently.
I believe the tabs on the wire-side hook-in under the top of the socket.
Any how try doing that gently
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
David Peddle será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 94
