Ir para o conteúdo principal
Um notebook da Toshiba com tela de 15,8" que roda Windows. Possui um reparo direto, semelhante à maioria dos notebooks. Requer apenas uma chave (de fenda).
How to safely remove plugs
Imagem
Hi,
I would like to know how to safely unplug some connections underneath my keyboard. My first attempt ended in frustration as the plug would not come out of the socket. I did not want to force it , as I was afraid I would break the connection. Every video I see online shows the plug coming out with ease, but not mine. Am I doing something wrong?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Off hand, I would try pushing down gently on the two white tabs in the indent on your photo and pulling gently.
I believe the tabs on the wire-side hook-in under the top of the socket.
Any how try doing that gently
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
David Peddle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 281
