Ir para o conteúdo principal
7th Gen Amazon Fire HD Tablet was released June 2017. It has since been discontinued and replaced by the current Fire iteration.
Cracked LCD and touch screen on Fire 7 9th generation
I got REALLY upset and destroyed the screens of the tablet. The digitizer, LCD everything. I found a new screen for it, and I want to buy it! But here is the problem, I have no tools! Are there any household items that would work for any tools I would need? Thanks! -Blackcomb
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Indeed! you could use a hairdryer to loosen the LSD Tweezers for any inside work. But a wedger is needed along with a suction cup
por
my screen is not responding it still works it just don't take input
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@blackcomb there really is no good substitute for the right tools. All you would need is a set of small screwdrivers and a couple of guitar picks to remove the screen from the case. You could use a good hair dryer to loosen the LCD. All of that should be relatively easy to come by. This shows how to replace the screen.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Blackcomb6.1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 1,406
