How to change rear battery cover?
I want to change the rear battery panel because it's got some using marks and looks really bad
Esta é uma boa pergunta?
ybo.shooter check this video you need a heat gun as your main tool. Temperature on the back cover should be around 70deg C to loosen the adhesive. Not complicated just a bit tedious.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 480
