Ir para o conteúdo principal
The Fire HD 6 (model number PW98VM) is a six-inch economy tablet featuring two cameras, a speaker, and Amazon's Fire OS. Released in 2014.
Would Plugging in a cable to the bare motherboard be able to get data
So i have a kindle fire mobo that has had its battery connector taken out improperly. I cant solder each of the points into a new battery as i am not that skilled at soldering. If i plug in the bare mother board (no screen, battery or anything) and as long as nothing is bridging, can i recover the data from it without frying anything
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Ryan Graham not unless you connect the LCD as well as the rest of the peripheries. Your Kindle will most likely looks for those during its POST and will hang up if not connected. Give it a try and see what it does.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ryan Graham será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 19
Ao todo: 251
