Ir para o conteúdo principal
How to fix iPhone not connecting to wifi
I have a iPhone 6s plus that when I try to connect to wifi the button is grayed out I have reset the network setting and just all settings and I still cant get it to work I'm going to try and update it but i don't think it will work any other things i can do
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
the wifi chip needs replaced
Esta resposta foi útil?
Pontuação 2
2 comentários:
ok i will try this
por
@keith_themuscovyduck Remember you will have to unbind the Wi-Fi Address from the NAND if you replace it.
por
If the setting is greyed out, more than likely this is a hardware issue. You can certainly try resetting the device, but in all likelihood, it will not make a difference. Either the chip needs to be replaced, or something in the WiFi circuitry has sustained damage or has gone bad.
Pontuação 1
Adicionar a sua resposta
keith_themuscovyduck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 61
