Ir para o conteúdo principal
Repair documentation for the initial Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1
52 Perguntas Visualizar todos
Why does my Ps5 controller lose bluetooth con to pc after aprox a 1ft
My Ps5 Controller works fine while wired. But Bluetooth connects to my pc a little slow, but it works. Unless I hold it extremely still and close to my pc it will have a continuous input of the last action on the controller. The PC says it remains connected. And if I move it another foot or turn in my chair the led turns red. I tried it with and without windows Ds4. I ran a troubleshooter for Bluetooth, reinstalled and updated all of my drivers, checked my wireless adapter. I've tried solutions from 7 different sites, none have worked. I can't tell if its a problem with my PC or my controller.
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Do you have any other Bluetooth devices to try such as headphones? If you do see the same problem persist you will know if its your pc or controller. Also do you have anything near your pc that could run interference such as a router it could block out Bluetooth waves.
Esta resposta foi útil?
Pontuação 0
1 dos comentários:
I've tried nearly every solution on google, I tried the controller on three different PC's. I don't have a problem with any other devices, my conclusion is something is wrong with the controller. Do you happen to know where the transmitter on the controller is located?
por
Adicionar a sua resposta
bonehead será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 232
