Ir para o conteúdo principal
Replacing Nand Flash with higher capacity without restoring
As the title says, I want to replace the Nand without updating ios. Most threads I have seen is people having fail nand flash memory.
i have experience on how to replace its nand flash, but usually the new nand needs to be erased and programmed in order to work.
but my case is if I have a working 32gb nand and I want to upgrade 256gb nand. Can i clone the contents of 32gb to the other memory? Would that work? Because i dont want to hit ios 15 because theres no jb for that version
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I also have the same problem, I wonder if it is possible with a nand programmer to extract a disk image file (encrypted of course) and then be able to flash it on a larger nad. This way the iPhone should recognize it as it is always encrypted, but I have no idea how to do it 🤯. @tomchai I think he can help us 😬
por
Adicionar um comentário
1 resposta
Pergunta mais útil
the data on the nand that the phone is using now needs copied to the new nand in order to work. you could download a lower ios and flash it using 3utool.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Wouldn’t it still need to be signed? Which would still leave you at 15.4.1 at the time of writing which has very little progress in terms of jailbreak.
por
Adicionar a sua resposta
ryeisqt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 613
