Ir para o conteúdo principal
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
67 Perguntas Visualizar todos
Why one drive side has less power than the other?
I actually have a Craftsman Z6900 zero turn mower, but that wasn't an option to select.
My problem is that the drive on the left side is not producing as much power as the right side. On level ground it operates fine, but as soon as I have to go up a hill I have to fully engage the left side (and I hear a groaning sound, like power steering in a car when the fluid level is low) but the right side can stay just partially engaged and provides plenty of power. I have read that my mower has a hydrostatic transmission, but I have no idea if this one is serviceable or how to do that if it is. Any ideas? Mahalo.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@phillfam10 looks like your mower uses a Hydro-Gear 2200 Integrated Hydrostatic Transaxle EZT Series for the drive. Those drives are a bit tough to work on etc. I would check the oil,and purge the unit. After that you may need to check the bypass and see if that is within specs. For all off that refer to the SM Hydro Gear 310 2200 EZT
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
David T Phillips será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Duração total: 452
