wifi and bluetooth not working
my wifi and bluetooth don't work after replace the battery
Esta é uma boa pergunta?
I would reseat the I/O data cable which connects the I/O board (with the Airport board) to your main logic board often I find the cable connection is the issue, you may need to replace the cable Substituição do cabo de dados da placa de E/S do MacBook Pro 13" com Tela Retina (início de 2013) if the Airport board is properly seated and the antenna cables are in good shape.
Esta resposta foi útil?
First thing I would check is to make sure that the antennas are plugged in properly. The order of the antenna cables is kind of weird (to me anyways). Step 10 of this guide tells you which one goes where.
Substituição da placa AirPort do MacBook Pro 13" com tela Retina de início de 2013
I would also make sure the cables between the I/O board and the logic board are seated properly, since that's what carries the signals for bluetooth and wifi over.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Ao todo: 642
