Ir para o conteúdo principal
O Samsung Galaxy Watch Active é um smartwatch projetado, desenvolvido e produzido pela Samsung Electronics, uma empresa sul-coreana de eletrônicos. Ele pode ser identificado pelo número do modelo SM-R500. Foi lançado em março de 2019.
Watch randomly stopped responding
My watch randomly died while I was at work. The screen went from working normally, to only showing yellow-ish lines and kind of fading in and out, to not displaying picture at all now.... It's still functional, still charges (vibrates) and before I reset it through the app, my notifications would still make it vibrate. I'm just wondering if I should replace the screen or another component. I bought it back in 2020 used and already beaten up pretty good, as a work watch. It's had a rough life, from sand/steel dust to machining coolant/oil in the past 2 years. I've taken it apart after it died, and it doesn't appear any liquid got inside, though the screws did appear to have some corrosion on them. (Could have also been spottily applied loctite)
Am I looking at a screen or main board replacement? Obviously since I've opened it I'll replace the battery as well. I bought a galaxy watch active 2 in the meantime, but I'd like to fix this one for my S/O. Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
The screen needs to be replaced. Link: Substituição do conjunto da tela do Samsung Watch Active
This is very difficult to do.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Clayton Smith será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 40
Ao todo: 702
