Why my battery is too weak
Esta é uma boa pergunta?
Hassan morray Koroma the battery is pretty much the only strong point on this phone. You should explain to us what you mean by the battery is weak. If you need to extend your battery life use the suggestions from here The battery life is only as good as you use it. The more you use it the shorter it gets.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 501
3 comentários
My battery is so weak
por Dore Mone
Mere mobile ki battery ki life dheere dheere Kam Ho rahi hai
por Md Azad
not charge up properly/long enough
por antonio
