Ir para o conteúdo principal
Guias de reparo para o Magic Trackpad. Lançado em 2010.
The pointer only moves vertically.
To be more precise there's only a narrow vertical band of the trackpad responding. Touching outside of this, central, band has no effect on the pointer.
I tried connecting it to another MacBook but with the same result. I’ve also tried to remove batteries and replace them with new ones and also to completely disconnect it but nothing.
The same thing happened a month ago, that time changing batteries solved the problem.
Do you have any idea?
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The sensor plate has become damaged. Did you drop it or sit something on it that could have damaged it?
Esta resposta foi útil?
Pontuação 0
4 comentários:
No, indeed I left it on my desk for one week during the holidays and when I came back it wasn't working.
por Compartilhar
@nikdef - Other than trying a fresh set of batteries they just isn't anything that you can fix (the Magic Trackpad2 has a sealed in battery).
por Compartilhar
It's just weird that it is sensible only in that narrow band. Thank you anyway.
por Compartilhar
@nikdef - Maybe the battery failed and pressed against the panel from the back side damaging it. Time for a new one.
por Compartilhar
Adicionar a sua resposta
Nicola será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 390
