Ir para o conteúdo principal
Released October 2, 2001, identified by model number DVP-FX810
Line in won’t work
Line in won’t work with my thing
(Wii av port)
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Logan Lamothe your "thing" being a DVP-FX810? Sounds like you are trying to connect a WII to it. Is that correct? What happens when you try?
por
No picture appears and it still says line in
por
Adicionar um comentário
1 resposta
Logan Lamothe follow the instructions in your manual. If you do not have one, you can download it at places like this
You need to check/set the side switch LINE SELECT IN OUT and see if that changes anything. Of course you also have to make sure that your AUX cable is compatible. Double check the manual for all of this.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Logan Lamothe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 195
