Ir para o conteúdo principal
How to fix the battery
When my battery gets to 25% it comes to 0% so quickly
Esta é uma boa pergunta?
Pontuação 16
6 comentários
Battery problem fast finished pleas reason
por
Phone camera dirty problem
por
Portuguese: Minha bateria está estufada e quando eu tiro o cll do carregador em poucos segundos ele desliga e liga descarregado
Ops: mesmo em 100%
Inglesh: My battery is full and when I take the cll out of the charger in a few seconds it turns off and on when discharged
Oops: even at 100%
por
por
How fixed to device bettery
=== Update (09/06/23) ===
How to repair Mobile bettery
por
Exibir mais 1 comentário
Adicionar um comentário
3 respostas
Pergunta mais útil
Use the phone until battery gets 15 : 20%, then put your phone on flight mode and reduce brightness then use this code
*#0228#
It will restart your battery.
Charge your phone until 100% for the first time
Esta resposta foi útil?
Pontuação 4
Try this:
  1. Use the phone until the battery gets to 0%
  2. Turn the phone on and wait for it to shut off
  3. Keep turning the phone on until the phone battery is pretty much drained
  4. Plug the phone into a charger
  5. With the phone off, keep the phone on the charger until the phone had been on the charger for a few hours after reachy 100%>
  6. Try the phone and see if the problem still arises.
Pontuação 3
1 comentário:
Change camera
por
This is common when your battery is getting old. It happens after 3 years of use. Please plan to change it.
Pontuação 1
Adicionar a sua resposta
I am Me será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 3,320
