Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 Perguntas Visualizar todos
Repurposing iMac to become a display
Hi,
I'm currently researching on ways to repurpose my iMac to being an external display. Since I would have the speakers, I was wondering if anyone knew an implementation on how to have the speakers connect to this display panel board https://www.aliexpress.com/item/33014928...
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Giovanni Morabito the description does not show the board well. Since it has an audio out jack for headphones I would use that with a small pre amp. Easy build and not to costly at all.
Esta resposta foi útil?
Pontuação 0
5 comentários:
@oldturkey03 any preamp suggestions? and also how could I get the preamp to have power
por
@Giovanni Morabito that's what I'd be looking at. You can get the power from the same AC adapter that your are going to use for the driver board. You know it's going to be a fun build.
por
@oldturkey03 any videos to show how to wire from an ac adapter? never really worked with wiring before LOL
por
@Giovanni Morabito not really but go ahead and purchase the driver board etc. Once you get the parts let us know (and see) and we can draw you up some simple diagram.
por
Adicionar a sua resposta
Giovanni Morabito será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 264
