CD opening isn't opening
- CD opening isn't opening
Esta é uma boa pergunta?
Ali HD1 you really did not give us a lot of information. It sounds like you are saying that your tray is not opening. You should also tell us more about the history of this and what you have tried thus far to fix this. I suggest that you run the Test mode to see if you can make a better diagnosis on what has failed. Sony DVP NS715 Test Mode
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 377
Need a bit more here!
∙ Do you hear any sounds?
∙ Is the player powering up?
∙ Do you get an error code on the display?
por DanJ
Do you have a multimeter?
por Andrew S
