Ir para o conteúdo principal
The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
A.C Not working in front of the vehicle
Just getting hot air. Even after i move the switch to the A.C Possition is still blowing hot air
Esta é uma boa pergunta?
Pontuação 1
1 comentário
You might be better served finding and joining Ford Explorer forums where similar owners share answers.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
There are a few basic points that you have to check if getting hot air from AC.
  1. Check the AC mode. Change it to the cooling mode.
  2. Clean dust and slit from the fin of the AC. Use water and soap foam to clean it.
  3. Check the temperature sensor.
  4. Confirm you have cooling gas in your AC and the compressor is working.
Esta resposta foi útil?
Pontuação 3
I paid $500 to replace the compressor, only to find out it was just a loose connector on the condenser fan…
Pontuação 0
Adicionar a sua resposta
Edilberto Sibrian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 456
