Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
20 Perguntas Visualizar todos
The size of the square nut?
whats the size of the square nut that is used to hold the battery cover on? Can it be order/found from a hardware store?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Not sure about the size, but I doubt if you can buy it separately. I know that if you buy a new shell (for example at AliExpress), you will get a new square nut, which you can transfer to your current back cover.
Example: https://godofgamingshop.com/collections/...
You could also contact them if they have a square nut available.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tyrantin DB será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 18
Duração total: 385
