Radio and gages only work when pressing brake pedal
Also you only have communication when pressing brake pedal
Esta é uma boa pergunta?
Please check your brake light switch and the radio power wire (or any others) and verify that the wires have not melted /shorted together. These wires will be located under the dash probably in a bunch. You may have a blown radio and dashboard fuse /cut wires and the brakes are supplying all the power!!
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 41
What do you mean communication? Have you checked your wiring? Is there a short somewhere?
por brandon k
