How to swap ac port card with a card with a usb c port
how do i do this and whats the best card to use as a replacement/swap
Esta é uma boa pergunta?
Hi @cryo420 ,
You can’t do this. The motherboard isn’t designed for it.
The laptop has a DC-In jack that plugs directly into the motherboard where it then connects to the various power mosfets, controlled by the IO chipset for power distribution within the motherboard.
To gain the advantages of a USB-C connector requires that 24 wires be connected from the USB port to the USB-C controller on the motherboard, which the laptop hasn’t got.
Trying to connect a USB-C system to the motherboard would require major modifications to the motherboard and is not something that can simply be plugged in
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 40
