Clutch beeding master cylinder
How do i bleed a 1984 clutch?
Esta é uma boa pergunta?
Here is what the service manual says "Fill Clutch reservoir with brake fluid. Check the reservoir frequent. Add fluid if necessary.
Connect Vinyl tube to bleeder plug. Insert the other end of tube in a half-full container of brake fluid. Bleed Clutch Line. Slowly pump the clutch pedal several times. While pressing on the pedal, loosen the bleeder plug until the fluid starts to run out. Then close the bleeder plug. Repeat this procedure until there are no more air bubbles in the fluid." you can download the clutch section of the service manual from here.Hope this helps, good luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 2,453
