Ir para o conteúdo principal
wifi doesnt work on my iPod touch
when i go to my settings in my ipod touch i dont even have the option for wifi. the wifi option comes up but i cant click on the button. does anyone know how to fix this problem???? i have tried to restore it and i have shut it off and turned it back on
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
holly, here is what Apple suggest. try this first "Resolution
If you encounter this issue, try the following steps and attempt to enable Wi-Fi or Bluetooth after each one.
Verify that Airplane Mode is turned off.
Update your iOS device to the latest version of iOS.
Reset Network Settings. To do this, tap Settings > General > Reset > Reset Network Settings
Restore your iOS device in iTunes." from here. If that does not work, you may have to disassemble your iPod and take a look at "The wifi assemble is at the top right corner of the device, right behind the black shield that is visible on the backside of the outer stainless shell. If you remove the three screws that holds the entire top pcb assembly in place, and gently lift the ribbon wire that connects the top and bottom half, on the backside of the top PCB assemble, you will see a small rectangle metal cover. This covers the broadcom chipset for the wireless." thanks to microdynamics on here. There is more about that on here. Of course you also should make sure that you are in a WiFi area....Hope this helps to get you connected. good Luck.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I've tried every thing 10 times or more apple couldn't give me a straight answer I didn't try taking apart but that's a last resort right now
por
You go to reset/genral/reset/reset wifi networks and then wait for it to come back on and then try again
Pontuação 0
Adicionar a sua resposta
Holly será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 8,992
