Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
iMac 2015 27" Fusion model query
Hi, on the 2015 Fusion model, is there any reason why I can’t remove the small 128GB blade SSD and replace the 2TB mechanical HDD with a 2TB 2.5” SSD?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Totally doable.
You could even leave the blade drive in there and still upgrade the HDD to a 2.5” SSD if you wanted. And then not have to muck around with getting the board out, just to take that drive out. Once the HDD is removed the Mac will recognize the SSD as a separate disk, rather than part of the fusion and you can just format it for extra storage. Or keep it as a boot drive and use the 2TB SSD for storage.
Esta resposta foi útil?
Pontuação 2
I think it should work but if you are removing the blade, why not upgrade it instead? It has faster speed.
Pontuação 1
2 comentários:
Thanks, the 2TB Blade SSDs are not within budget unfortunately.
por
Ah. That makes since. It should work fine.@itpeople
por
Sure you can remove your current HDD and replace it with a 2.5” SATA drive Substituição do disco rígido do iMac Intel 27" com tela Retina 5K but the performance will be limited to the SATA I/O unlike the PCIe/NVMe interface. While having a large 2TB drive is nice you may find going with a smaller PCIe/NVMe drive and using it as your boot drive with your apps will give you better performance and use your current HDD as the data drive iMac Intel 27" Retina 5K Display Blade SSD Replacement
Imagem de iMac Intel 27" Retina 5K Display Disco rígido
Guia
Nível de dificuldade:
Moderado
1 - 2 hours
Imagem de iMac Intel 27" Retina 5K Display Blade SSD
Guia
Difícil
2 hours
Pontuação 1
Adicionar a sua resposta
ITP será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 79
