Ir para o conteúdo principal
O Super Nintendo Entertainment System (SNES), ou simplesmente Super Nintendo, é um console de 16 bits lançado pela Nintendo em 1990. O Super Nintendo foi um dos mais vendidos de sua época e ainda possui uma grande base de fãs hoje em dia.
No Power Issue SNES
My SNES has stopped working, measuring the output of the power cord, the max I got was 1 volt, does this mean it is the power cables fault? This all started when the console fell, so I have checked the insides of the console and the charger, the console looked completely fine on the inside. I tried to measure from the chargers transformer itself but I don’t know which parts to put my prongs on. Most likely I think it’s the cable, I don’t think it’s the power connector itself, I have measured around the same voltage on the console itself that I did on the power cable. On Continuity mode, I put one prong on one of the power prongs, one on the other side of the cable, no beeping.
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
We have found that this issue can be caused by using an underpowered AC adapter or power source. The problem can be resolved by using a licensed AC adapter. You can purchase one from the Nintendo Store. If a licensed AC adapter is unavailable, you can try using a different AC adapter that is rated as 5V/1A. Now i am sharing this helpfull answer No Power Issue SNES- apkbik
thanks
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Connor Steffenhagen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 1,014
