Ir para o conteúdo principal
O Logitech Performance MX Mouse é um mouse premium da Logitech com tecnologia de rastreamento Darkfield e uma roda de rolagem de giro livre. Lançado em 2009. Número do modelo: 910-001105.
What can cause an erratic tracking problem?
My mouse pointer doesn’t track across a document or any file on the screen evenly, The mouse mat(s) have not changed but the problem is getting progressively worse. I changed the battery. I have tried cleaning the laser port cover on the mouse but it didn’t make any difference. I have two of these mice and they both have the same problem. They need repairing, can you tell me if this is possible, please? They are 9 years old and were quite expensive, about £50 each, I wonder if spare parts would still be available.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If it’s a hard mouse pad, it could be the mousepad is worn and too glossy for it to work well. Try it on a sheet of paper, and if it’s still doing it, it could be the laser is losing power or the battery may be getting too weak to power the laser.
The Laser bounces off the surface and goes into a receiver which is beside it, so make sure it’s clean too.
There are several manuals for tearing down the mouse too that should help.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Anthony Osborn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 28
Ao todo: 767
