Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
20 Perguntas Visualizar todos
My phone won’t turn on!
I replaced the screen on a customers phone and the phone won’t turn on. When I plug it in, it vibrates and makes a noise, but the ringer switch won’t work and a force restart does nothing. The home button also doesn’t respond with a click. What do is do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Have you seated everything correctly? has the display been calibrated by the IMEI swap tool?
Esta resposta foi útil?
Pontuação 0
7 comentários:
I haven’t calibrated the screen but it isn’t required right? The True Tone just won’t work. I’ve made sure everything is connected. I’ve checked the pins to make sure none are bent or broken.
por
@the_tech_noodle Yup, thats for sure an uncalobrated screen. Its gonna cost a good $500 for a tool to take the IMEI from the old screen and transfer it to the new one.
por
Even the original screen won’t work.
por
And it doesn’t show up on iTunes @bezzzles
por
@the_tech_noodle Is the battery all good?
por
Exibir mais 2 comentários
Adicionar a sua resposta
Micah P será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 63
