Psone lcd screen flickers purple.
Hello my PS1 LCD screen has been turning purple until removing the screen and putting it back on to the PlayStation here lately and I'm not quite sure why?
Esta é uma boa pergunta?
@squanchfu it’s getting up there in age and may show signs of some corrosion, failing caps or degradation of the solder connections. I suggest you start with a new pair of AV cables and try that. If that will not work, time to open it up and have a good look around to see if there is any obvious damage. After that I’d consider a total recap of the PCB. If you have to open it up post some good pictures of the mother board etc., with your QUESTION so that we can see what you see. Adicionar imagens a uma pergunta já existente Substituição da placa-mãe do PlayStation One
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Guia
Fácil
3 minutes
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 388
