Ir para o conteúdo principal
A1418 | EMC 2889 | final de 2015 | Intel Core i5 dual-core de 1,6 GHz ou Intel Core i5 quad-core de 2,8 GHz. Lançado em 13 de outubro de 2015.
LCD Inverter Power Backlight Cable
Imagem
Hi, there. Wondering what’s wrong with this top LCD light (please refer to attachment)? As it won’t on when iMac is turn on, the other 3 LCD lights are OK. Is it LCD Inverter Power Backlight Cable is faulty? Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Thanks, Dan. I thought the image was uploaded together with the post.
por
Adicionar um comentário
1 resposta
Reconnect the display making sure you properly seat the connections. Use some painters tape to hold the display. If you get an image tale a picture and post it. If you don’t plug in an external display does it show your desktop? If you can’t do that take a flashlight pressed on the display in a dimly lit room you should see a faint image of your desktop and/or do you see a slight glow from the display?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kenny Sim será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 346
