Ir para o conteúdo principal
Número do modelo A1707. Lançado em junho de 2017, este MacBook Pro possui processadores Kaby Lake com até Intel Core i7 quad-core de 2,8 GHz com Turbo Boost de até 3,8 GHz.
A1707 Keyboard Replacement Process
Any documented processes out there? I bought P/N IF123-122-1, however there are no iFix it Guides. Looks though videos, it seems you literally fave to rip apart the old keyboard and cut off rivets. However I do not see a good way to put it back together.
Thanks
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
I’m not sure if we are allowed to post a link here, but here is a video that gives you the instruction step by step:
http://www.powerbookmedic.com/manual.php...
Esta resposta foi útil?
Pontuação 0
2 comentários:
unfortunately the Video does not show the keyboard removal.
por Compartilhar
Here's a good video with all of the blood & gore! How to replace Keyboard for Macbook pro 2017 A1708 (Complete disassembly)
This is not something I recommend for DIY job. Even I don't replace the keyboard in this series as its just too much work and risk. I strongly recommend you just buy the full uppercase unit (even with a new battery) as being the smarter direction!
MacBook Pro 15" Retina (2017) Upper Case
MacBook Pro 15" Retina (Late 2016-2017) Upper Case Assembly
por Compartilhar
Adicionar a sua resposta
Keith Templin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 61
Ao todo: 4,786
