Ir para o conteúdo principal
Repair documentation and service information for Hisense televisions.
143 Perguntas Visualizar todos
HISENSE tv sound but no picture 75h6570g
I have a 75 inch hisense tv ( 75h6570g ). I get sound on the tv but no picture unless I hold a light up to it. I’ve taken the tv apart and replaced the power board and the issue is still the same. I can hear sound and only see a picture when I hold a light up to the tv. What should I do next ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @brokentvmatt ,
Seems like you have a backlight problem.
This could be either faulty LED strips or since you have replaced the power board, the mainboard telling the power board not to turn on the backlights for some reason.
Without a schematic (I can’t find one) to know where to check voltage signals between the mainboard and power board and as the audio is working and you can “see” video, to me it points to the problem being either the mainboard or the backlights.
Since you have the TV dis-assembled, consider getting a backlight tester (supplier example only) and connecting it to the disconnected LED power cable, (assuming it is connected to the power board) to test the backlights, independent of the TV being powered on.
If all the backlights turn on, then it’s looking like a mainboard problem
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Matt hildebrand será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 987
